Front Strut Replacement Options IX MR
Old Sep 19, 2016, 11:17 AM
gizmogyrl27's Avatar
I have to replace my front struts on my 06 EVO IX MR. Are the Bilsteins the only ones that will fit? Or is there another option that will fit. Ideally I'd love to replace with the Bilsteins but funds are somewhat tight and would like a cheaper alternative in the meantime.
Old Sep 19, 2016, 11:27 AM
CaptainSquirts's Avatar
You could buy some used kyb struts(came on the non MR models).
Old Sep 19, 2016, 11:30 AM
Thanks. I was looking into those, but were unsure if they would fit. Do you know if they will? I know they make some that fit the rear, but I am replacing the front.
Old Sep 19, 2016, 11:42 AM
heel2toe's Avatar
Yeah the KYB's fit fine as long as they came off of a VII-IX
Old Sep 19, 2016, 11:44 AM
So I should be good with ordering the KYB replacements then?
Old Sep 19, 2016, 12:38 PM
heel2toe's Avatar
I die a little inside thinking about replacing the Bilsteins with KYB's but yeah they will fit fine. Have you looking into sending your old ones out to be rebuilt?
Old Sep 19, 2016, 01:23 PM
I have. But I really think just ordering and replacing is the way to go to avoid unnecessary downtime right now. Thanks!
Old Sep 19, 2016, 01:26 PM
kyoo's Avatar
should be able to find used ones on the forums
Old Sep 19, 2016, 01:42 PM
LetsGetThisDone's Avatar
Received 1,571 Likes on 1,348 Posts
You can get Bilstien B6's from rock auto. I would go that route.
Old Sep 20, 2016, 05:29 AM
I believe the kyb struts new are very very very expensive. Like 300ish per strut. So if you're tight on money getting a used pair or struts seem like the way to go. The suspension geometry won't be the same if you get kyb struts in the front and have bilsteins in the back compared to having bilsteins in front and back. Or you can get replacements bilsteins new for like 350 a pop. I was in this scenario and I just ended up being a whole set of used struts.
Old Sep 20, 2016, 12:38 PM
The suspension geometry would be identical. It would be the damping the shock generates that wouldn't match front to rear.
Old Sep 20, 2016, 01:05 PM
Thanks for all the help. I ordered them and hopfully will be back on the road soon!
Old Sep 21, 2016, 05:59 PM
Just to confirm I ordered correctly, which of these are compatible with the evo 9 mr? Thanks
Old Sep 21, 2016, 06:18 PM
Biggiesacks's Avatar
well neither of those say Lancer Evolution so...
Old Sep 21, 2016, 06:22 PM
Yes..... and as stated in original post the bilsteins are the only ones that do. Which is why I was asking if anyone knew if any others would fit. But thanks for the completely obvious input.
Quick Reply: Front Strut Replacement Options IX MR
