Lower Spring on stock shock
I have seen lots of ppl using lower spings (like Tanabe, s-tech, pro-kit) with the Stock Shock on their Evo. Most ppl have good result and very please with the perfromance.
My question is how well you guys think the stock shock can be lasted with a set of lower spring? My experience told me that in many case the stock shock usually wear out pretty fast w/ lower spring since the stocker is not design to the aftermarket spring rate.
Since the Evo using Inverted Mono-tube shock from the factory.....you guys think it can handle and last longer with higher spring rate? I want to buy a set of s-tech/ tanabe like many ppl......but I just worry about the perfromance in the LONG RUN.
TIA
TIA
Originally posted by ChrisS.
My rear shocks are starting to got out..........seems that way anyway..... had the springs on for about 4 months....
i installed my Eibachs at about 100 miles and my shocks are still fine and im at almost 10,000 almost 1 1/2 years ago. the fact that it is an inverted monotube means nothing, since regular shocks are a monotube. so really a "normal" shock is turned upside down. no different.
project_lancer
47
May 19, 2013 03:18 AM
shinbumee
May 4, 2008 03:21 PM
