Wheels aligned but still pulling towards right
I was wondering if anyone has a had a problem with their EVO pulling towards the right, even after a wheel alignment? I got the specs from the dealer and the tire shop aligned it accordingly, but it still pulls to the right. The tire shop said it could be something wrong with the rack and pinion. Has anyone else had this problem? Help!!
mine pulls
I bought a set of ContiContactors (sp?) and have had the same problem. Being that the tires are unidirectional I swapped the front R (pulling to the right) to the back and it helped, but all I can think of is a tire with a little 'radial-pull.'
BTW I had my EVO aligned also...and its within really good specs.
Thanks,
jcnel.
Thanks,
jcnel.
I bought a set of Falken 512's, 245/45 ZR17's and have the same pull. I too had the car aligned twice and replaced one of the tires after rotating them and nothing worked. The tech then brought one of the brand new Evo's from the lot over and swapped the rims/tires (back to stock) and the car drove straight
I can't figure it out but it is very frustrating. I should also note that with my stock tires I had uneven wear and they were in need of replacing within 9/10K (the insides wore extremely fast). It's never been to the track and I don't get much of a chance to drive it hard where I live. And yes I rotate my tires every 3K miles so it's not from a lack of maintenance. If anyone has any suggestions it would be much appreciated.
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Re: Wheels aligned but still pulling towards right
1) The road is 'crowned' (higher in the middle for rain drainage) Drive down a side street on the left hand side and check if it pulls to the left.
2) Did you witness the alignment? Just cause the alignment is "within specs" doesn't mean that it is even.
yup.
Yup, I witnessed and even participated in the alignment. (In fact I knew more than the tech. that did the alignment...sheesh...its not rocket science.)
Anyways...I've not seen any 'real' absurd tire wear on what I think is the offending tire...but then again I've only been on the Contis for about 5k miles.
Later,
jcnel.
Later,
jcnel.
Re: Re: Wheels aligned but still pulling towards right
Originally posted by mhgsx
2 things jump immediately to mind.
2) My dealer insist that I stay with the car whenever possible so that I can witness anything and everything they do to or for the car. So yes I was there and also participated in the aligning of the car.
I'm hoping that it's something simple, but with my luck my car will blow up before I figure it out.
Re: Re: Re: Wheels aligned but still pulling towards right
Originally posted by Evulized
1) We did this and my car pulls to the right side of the road, and the tires are too new to show any uneven wear, yet...
If you think it's the tires, rotate them left to right, and see what happens.
Ralliart367
39
Jan 29, 2013 07:37 AM
samterry1234
18
Dec 30, 2011 08:49 PM
dewman1999
10
May 1, 2005 02:21 PM
