New Products Offered At The Tire Rack
G-TECH/Pro COMPETITION
The award-winning G-TECH/Pro COMPETITION will give you the performance answers you’ve always wanted. It’s like having a Drag Strip and a Dyno all in one. High accuracy is achieved by using three precision accelerometers and full-temperature compensation. Developed by Jovo Majstorovic, winning racecar driver and TESLA Electronics president, the G-TECH/Pro COMPETITION eliminates all guesswork and provides instant results before and after modifications.
Easy-to use, no installation, no wiring. All you need to do is plug it into your 12V cigarette lighter and attach the custom-designed suction cup mount to your windshield.
Acceleration times to 1/100 sec.
Measures 1/4, 1/8, 60', 330', 0-60 and more (see complete list below)
Gs, HP and torque graphs
RPM sensing with no wiring or hookups
Intelligent Shift Light and Cornering Lights
No installation, three accelerometers built in
Includes 12V cigarette lighter DC power cable, AC power adapter, and a serial cable to transfer data to a computer
Aluminum Floor Jack
• Heavy duty 3000 lbs. max weight capacity
• Lightweight (37.5 lbs total jack weight)
• Low 3.5" minimum saddle height, 17.5" maximum saddle height
• Two-piece collapsible handle (4'2" total length)
• 90 day limited warranty
• Seal rebuild kit included
Hella Airpower 115 Universal Air Compressor
12V vehicle power source plug and cord, four (4) valve adapters, a 165 p.s.i. air compressor and built-in, practical work light. Air pressure is measured and displayed on the easy-to-read dial pressure gauge.
You can see these and other great new products at the following link: Other Tire Rack Products
Aluminum Floor Jack
Originally posted by Mitchubishi
Does that air compresser have nipples for other things, for example an adapter for a presta valve on high end MTB. Bikes? I see the ball in flater, that's cool, but if this has a presta thingy, I'm hooked.
drevoviii
For Sale - Miscellaneous Automotive
Nov 24, 2011 08:52 PM
Neal@tirerack
Jun 21, 2005 11:19 AM
Neal@tirerack
Aug 5, 2003 11:57 AM
