Lower rear control arm and ball joint?
Hey so I finally found out a clicking noise and narrowed it down to my back left, I need a rear ball joint. I’ve called around but not getting a lot of answers or getting the run around. Can I replace just the ball joint? Yes I’ll need to press it, but where can I just get a rear ball joint, or do I have to do the full lower control arm and ball joint replacement? This clicking is only from a start and when I turn. It’s looks like it needs changed compared to my right rear
This is the rear left lower ball joint.
Our good vendor MAP carries the HardRace rear joints
https://www.maperformance.com/produc...hoC2RYQAvD_BwE
I recently changed out all the ball joints (front/rear) and bushings on my IX. Are you planning on changing out the ball joint yourself? It's pretty easy if you have a press, I used a 27mm socket to press out/in with a sleeve to support the bottom of the arm. Make sure to torque everything down at ride height when reinstalling the LCA.
I was originally going to order through MAP but their site said 6-8 weeks for delivery. I ended up ordering from https://www.cj-motor.com/hardrace-re...-lancer~233886 in AUS, they arrived in about a week.
Well said. Same part as MAP sells
hey bro, yea im going to do both rear lower control arms, with ball joint assembly. will eventually do the fronts. I've replaced the front rack and pinion, and front cv joint axels as of now. I have them ordered and will be here soon. I don't trust myself to press, so going to have it done n a shop I trust.
