Enkei PF-09
Those look bad ***. I do have a question. Being I went from a 255/40/17 to a 245/45/17 what did you do for your alignment? I am looking for some info on how to get these to work on my car with Nto3's.
About 0.5" increase in OD going from the 255/40 (25.1") to the 245/45 (25.6"). A quick alignment might not be a bad idea for optimal performance, life span and fuel economy but it won't be huge.
I'm coming from a 245/40/18 (25.7"). However, the last time my car was aligned I did so on my "track" wheels...18x9 +35 with a 255/35/18 (25.1" OD). I know the alignment is probably not optimal with the larger OD but drives nicely. I have a bit of work I want to do before I align it again...outer tie rods etc.
This past sunday at the local autox....haven't put these wheels on in a while. 595 RS-RR. Glad I got another rip with these tires for comparison to these new tires.
Crzykdd (Dec 14, 2021)
The following 2 users liked this post by Apex Hunter:
EVO196 (Dec 14, 2021),
MinusPrevious (Dec 12, 2021)
Apex Hunter (Dec 12, 2021)
Yeah so I had hoped...see post #12.
i have a set of 9" wide +35 RE30s that have a ton of caliper clearance. Unfortunately not the case here due to face design. These give best caliper clearance further from center due to the aggressive concave.
So in post #12 I did the test fit; seems I need 7mm of spacer minimum to achieve a "safe" 3mm clearance.
Russell K
45
May 12, 2015 07:28 AM
RallySport Direct
Evo 'For Sale' Wheels / Tires
27
Jan 19, 2015 10:38 AM
RallySport Direct
EvoX 'For Sale' Wheels / Tires
Aug 18, 2014 11:02 AM
IMPORTIMAGE
311
Jun 25, 2007 01:21 PM
Ninosautoacc
Apr 12, 2004 06:33 AM
