Brake rotor turning
revisited
Thanks for the suggestion...I was in talking to my Mitsu. dealer today and got a quote for a brake turn, and a set of pads. $800.00 freeking dollars. Well...it "IS" a performance car.
In any case...they made the argument that having an on car lathe turn the disks would elminate the hub to disk variance that could occur (tech was talking about 1 thou. here). While I believe this, I've done many a disk swapout on sportbikes (tighter tolerances?) and just clean the mating area really well, and prep the hub with some light scotchbrite. They've all been ok...so...
If I get the rotors turned at a local Autozone, would they go back on the EVO within "nice" tolerances. Or...
Has anybody turned their rotors off of the car and had good luck in putting them back on without 'any' problems?
Thanks,
jcnel.
P.S. I know this would void the brake warranty, but I'm willing to take the 'hit' on the braking system.
Thanks,
jcnel.
Don't do it
Brake rotors have to be turned on the car. I already made the mistake of taking the rotors to Pep Boys to turn them, which made the car almost undriveable. Immediately after putting them on the car it would shake violently when applying the brakes. I had to take it to the dealer to have them cut right. Rotors have been cut 3 times now.
Thanks,
jcnel.
Thanks,
jcnel.
That is true about the hub to disc. One way to eliminate that is to index or mark the rotor to hub placement before removing.
jcnel_evo8
May 2, 2004 08:18 AM
jcnel_evo8
Oct 8, 2003 08:38 AM
