Help...uneven tire wear on stock suspension..evo8
...as i was doing my second oil change the car had about 7k miles on it. i have noticed that the two front tires had an uneven wear from the inner part...so i rotated the back ones to the front and i also did do the allignment the following day...the only wheel that was off was the rear left, others seemed to be fine...after putting about 800 hundered miles, the front tires seem to be doing the same thing as the previous ones...what i don't get is that i have a stock suspension, the car is not droped but im thinking of droping it so that my correct my uneven tire wear in the front...and then doing the allignment again with the drop on it.
I'm stumped! My first thought was your alignment but you're saying it's in spec. Can you post your Before and After Alignment specs. Also where did you get the alignment done from? Dealership or some other shop. You may want to take it in and have the dealership check it out...but to me it seems an alignment issue. What about tire pressure? What pressure are u running.
i would defenitly go to the dealer but the thing is that i do have a full stage 1 on the car and i already purchased the tein s springs...so once i put those on with the new alignment we'll see what happens then...but till then this whole thing is weird shi....
Originally Posted by whitet777
Just a shot in the dark, but are your tires overinflated? That would wear out the mid-section of the tire before the outer edges.
I was running 4psi from the get go over recommended, my tires were fine at about 17-18k. Then, they suddenly start wearing fast as you describe. I took it in for an alignment, and found all four tires were over 40 psi and the alignment was dead nuts on. Went home with a new pressure gauge and found my "old trusty" had failed and was reading 8-10 psi under.
could it be driving style? do you tend to carry long sweepers at the threshold of grip? My fronts did the same. Stock set up also, after about 15k miles of mostly highway (not freeway) driving.
mine is doing the same thing. it started at 2k miles, went in, had it aligned, the car is still wearing uneven on the inside of the front and back. my front tires of bald inside, the middles are good. the rear ones are wearing on the inside, but not as bad as the front, ditto with good rubber on the middle and outside. no my tires are not under or over inflated. i drive aggressively, but not too aggressively. thankfully i picked up a set of used advans to hold me til i trade it for an MR.
for the ones who have uneven tire weaar, do you know the exact # of what the toe, camber set at? and tire pressure? Don't just trust someone who told you they are within spec, get a before and after print out.
BuLocal
Dec 4, 2005 12:22 AM
