Directional Tires
Directional Tires
I had my tires changed from my winter tires...and I was looking at someones evo today and the tread was going the other direction..... Can the stock yokos go in both directions? or is something seriously wrong here....
For best, and safest results, you should always run a directional tire with the tread pointing toward the front of the car. Running the tire backwards is especially bad when its wet out. Instead of pumping water away from the tire, your actually forcing it underneath. This creates a high risk of hydroplaning.
If your not sure how the tire should be mounted, there will be a directional arrow on the sidewall showing its proper rotation.
![Thumb Up](https://www.evolutionm.net/forums/images/smilies/icon14.gif)
Well...it seems my arrows are pointing in the right direction... too bad I dont know the other guys contact info cause his tires were goin the other way ...
Bster13
25
Nov 21, 2008 11:02 AM
_Chris_
22
Jul 22, 2008 06:35 PM
Hen5000
Jan 23, 2008 04:49 PM
zakenjanei
Mar 18, 2005 05:59 AM
Aby@MIL.SPEC
Oct 1, 2004 09:03 AM
