Lug Nuts
Old Jun 1, 2004, 10:32 PM
EvoMike03's Avatar
Lug Nuts
Hey,
I know many of you have aftermarket wheels....what after market lug nuts do you have and where did you get them from? Also, what is the thread size and pitch for the evo wheel studs? I am getting the 5zigen fn01r-c and need to get some lug nuts that will fit.
Thanks,
EvoMike
Old Jun 2, 2004, 09:12 AM
EvoMike03's Avatar
anyone?
Old Jun 3, 2004, 05:56 PM
ReHeat's Avatar
Here are a few company you might want to consider McGard, Rays, Ralliart
The size for the lug nut is 12mmX1.5
Old Jun 3, 2004, 08:09 PM
brwnrice's Avatar
cheaper alternatives are zenki (forged) and muteki (duraluminum).
Old Jun 5, 2004, 12:31 AM
Lacoste's Avatar
Arrow
Mach V has the forged ones, and Summit Racing has the McGard spline drive lug nuts.
A lot of aftermarket wheels use 'tuner' lug nuts, which have smaller heads than the gigantic stock nuts.
Lacoste
Old Jun 5, 2004, 12:55 PM
Mach V Dan's Avatar
As Lacoste mentioned, we stock forged aluminum ones. I am using them on my on Evo with the FN01R-C's.
--Dan
Mach V
MachEVO.com
Old Jun 5, 2004, 01:20 PM
SidewaysEvo's Avatar
i would go with the rays lugs. those are pretty tight. they come in blue, red, and black. well worth it
Old Aug 12, 2004, 07:17 AM
mifesto's Avatar
--Dan
Mach V
MachEVO.com
hi, can you PM me regarding this? i'm trying to find a low priced aftermarket lug nights that save weight for my stock rims...
Old Aug 12, 2004, 08:52 AM
Mach V Dan's Avatar
The stock wheel uses a special Mitsubishi lug nut that has a built-in flange. I'm afraid there's no aftermarket replacement that'll fit the OEM wheel.
--Dan
Mach V
MachEVO.com
Old Jan 8, 2005, 04:28 PM
trinydex's Avatar
why do you need aftermarket lug nuts? because the stock ones have a flange?
sideways: where would you pick up some volk lug nuts?
Old Jan 8, 2005, 07:46 PM
Slowride's Avatar
Which lugs do the MR BBSs use?
Old Jan 8, 2005, 08:12 PM
SoR
SoR's Avatar
From what I've seen the exact same as the Enkeis.
Old Jan 10, 2005, 06:40 AM
00R101's Avatar
Skunk 2 makes a cool but expensive titanium alloy nut that will fit. It's incredibly light - 5 weight about what 1 stock one does. It's open ended so it works with longer studs. It has cool knurled end that make them easier to spin on. They cost $5 each. They have the angled seat you need for most aftermarket wheels. They will not work with OEM wheels. They are between gun-metal and bronze in color.
Old Jan 10, 2005, 11:59 AM
evo81's Avatar
the ones from machV are sweet.i have them with my 5zigen fn01r-c
Old Oct 11, 2006, 06:17 AM
kmcconn9's Avatar
well since the ones from machv are discontinued, what is everybody else running with these rims?
Quick Reply: Lug Nuts
