Will Enkei RPF1 17x9 +35mm offset fit on evo?
looks exactly like mine
except mine a 1/2" wider
the rear should fit fine
the fronts will need a 20mm spacer
you have the rwd version like mine
the face sits inboard more and has a little bit of a lip
the fwd the face sits flush to the lip
By "not fit" i mean you cant just pull them outta the box and throw them on
Not everyone wants to run extended studs and spacers. Since yours are 17x9.5 and you get away with 20mm spacers, I wonder if the 17x9s can get away with 5-7mm spacers. Id rather not run extended studs
FS[Northwest]: Enkei RPF1 18X9.5 - 38mm offset - Wheels only
awdboosted
For Sale - Wheels / Tires
11
Oct 30, 2015 08:33 AM
Jooyoung99
19
Jun 16, 2008 08:29 AM
Ninosautoacc
17
Oct 19, 2003 09:14 PM
