Power Power and more Power!!!
We have AEM UEGOS ready to go.
Fp turbos-
Evo green - Available
Evo red- Available
EvoX red- Available
Evo Black- Available
Fp turbos-
* FP Evo 9 Green 73HTA Turbo w/ 80mm Surge Port w/ 18 PSi actuator *Will Fit Evo 8 with new lines and a new compressor outlet elbow*
Evo red- Available
FP Evo 9 Red Turbo w/ 80mm Surge Port w/ 18 PSi actuator *Will Fit Evo 8 with new lines and a new compressor outlet elbow*
EvoX red- Available
FP Evo 9 Black 82HTA Turbo w/ 84mm Surge Port w/ 25 PSi actuator *Will Fit Evo 8 with new lines and a new compressor outlet elbow*
Product-
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
- Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
- Does not oscillate AFR reading like narrow band sensors
- No laptop required for monitoring!
- Bosch sensor included
- Accurate to 0.1 AFR
- Reads in AFR or Lambda via a switch in back of gauge housing
- 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
- Integrated three-digit display reveals AFR or Lambda in real time
- User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
- Serial data stream included for output of AFR (RS 232)
Chris
Maximum Output Motorsports
___________________________________
Email- Maximumoutputmotorsports@yahoo.com
Aim- Maximumoutpt
Phone- (239)297-7141
Address- 2634 N.E. 9th ave Cape Coral Fl. 33909 Unit 8
