TTP Engineering- Evo X dyno tuning results thread
Old Jan 7, 2009 | 11:11 PM
  #76
TTP Engineering's Avatar
STOCK INTAKE
STOCK CATBACK
STOCK UPPER PIPES
STOCK LOWER IC PIPES
STOCK FMIC
STOCK O2 HOUSING
STOCK BLOW OFF VALVE
STOCK CAMS
NO RACEFUEL
Old Jan 7, 2009 | 11:28 PM
  #77
EVIL_EVO_VIII's Avatar
Congrats Scott, i knew that car had it in it when i rode in it last time.Those are awesome times for a nearly stock X and on pump gas!!!!! Cant wait to see what it does on race gas and more mods
Old Jan 7, 2009 | 11:51 PM
  #78
compscibOi's Avatar
That's a lot of power for stock! As always, great job!
Old Jan 8, 2009 | 12:09 AM
  #79
Clark_Kent's Avatar
All I see is a red 'X'.
Old Jan 8, 2009 | 01:31 AM
  #80
Combatvetgsr's Avatar
12.0? Not bad
Last edited by Combatvetgsr; Jan 8, 2009 at 11:04 AM. Reason: Original question answered in Orlando thread
Old Jan 8, 2009 | 05:59 AM
  #81
Yes its a stock turbo
Old Jan 8, 2009 | 06:42 AM
  #82
Robevo RS's Avatar
STOCK INTAKE
STOCK CATBACK
STOCK UPPER PIPES
STOCK FMIC
STOCK O2 HOUSING
STOCK CAMS
NO RACEFUEL
so you say stock turbo.
What is actually is changed on the car besides the tune? these are hp or whp numbers?
because those numbers are incredible. tq 417 - hp 390.
Old Jan 8, 2009 | 06:57 AM
  #83
Geo@SpeedClinic's Avatar
That is awesome!!! Congrats Scott. Do you have a breakdown of the slip?
Does the zchip allow rev limiter adjustment?
I wish the info that is out now about tuning the X was out 6 months ago when my car was on the road. It would have been an entirely different beast.
Old Jan 8, 2009 | 08:22 AM
  #84
Question
when the car coming out Geo?
Old Jan 8, 2009 | 11:51 AM
  #85
Blazing VIII's Avatar
Originally Posted by TTP Engineering
The changes in parts consist of a Forge Evo X wastegate actuator, TTP-Engineering prototype downpipe, crushed stock Evo BOV, ZCHIP for Evo X, ECU controlled boost, TTP MIVEC custom mapping intake/exhaust. HFS5.
There is no longer an aftermarket boost controller on the car.
The car spiked 30psi and tapered to 16.5psi with the stock intake filter. With the filter removed it spiked 30 and tapered to 17psi.
The removal of the filter from the stock airbox added 8-10whp at 30psi. It is likely worth even less power at lower boost levels. We plan to thrown a low restriction dry drop in filter to replace the stock filter.
I have a question, how are you adding "MIVEC custom mapping"? The Zchip can't control that. Is there another product you are using, or have you now flashed the ECU? Same question for the "ECU controlled boost".
And what's "HFS5"? Is that that Aquamist meth kit?
Old Jan 8, 2009 | 02:00 PM
  #86
GST Motorsports's Avatar
NO RACEFUEL
Don't forget the HFS5 meth injection. Nice run.
Old Jan 8, 2009 | 02:07 PM
  #87
Meevo's Avatar
Impressive. Did the car run 11.7 with 3780lb weight too?
Old Jan 8, 2009 | 02:26 PM
  #88
We are using water injection to cool the exhaust temps.
Old Jan 8, 2009 | 03:35 PM
  #89
Robevo RS's Avatar
maybe Ecuteck?
Old Jan 8, 2009 | 03:36 PM
  #90
We are using a Forge UNOS boost controller.
Quick Reply: TTP Engineering- Evo X dyno tuning results thread
