My Evo X (and 135i) dyno tuning results over time
I have tuned my last 5 cars at Dyno4mance. It uses an uncorrected Dyno Dynamics. Yes, it reads low, but most of you should know that. An Evo IX that makes 300whp on this dyno will trap about 110-111mph. Here are some results:
First off, here's the X stock vs. a boost controller and cat-back vs an EcuTeK tune (ECU boost control) and the cat-back.
Next, I added a downpipe and test pipe.
I have a couple friends that continued on with their X and they did intercooler pipes. Those cars made an extra 10-15whp on top of that. 300whp is about equal to a bolt on IX. Of course, the X holds the power a bit better up top due to the square engine and amount of timing it can safely run. Sadly, this doesn't show at the dragstrip since the X weighs some 300 pounds more than the IX.
And here's the latest stuff on the 135i from the past weekend. Stock is violet at 252whp, the red run is the PROcede only at 308whp, and the black run is the PROcede with dual cone intakes at 330whp. Not too shabby for no exhaust work and all four stock cats in place, huh?
You mean that small spike in torque and HP i see in a narrow range in the middle before it takes a nose dive?
Im just pushing you buttons, lol, i know that motor is a beast.
