Evo X Kelford Stage 1 Cam Test
We finally got the Kelford stage 1 cams in our Evo X. With the boost set to 22psi the car made 357whp/319ft-lbs on the stock cams. With the addition of the cams and no tuning the car made 356whp/344ft-lbs. We will be tuning the car over the next few days so we will keep you guys updated. I will update the thread with the final numbers as soon as we are done tuning. With some more tuning and boost we are confident that the car should pick up a lot more. We will be doing a special this month for the cams installed. The price will be $1350. Here is the dyno sheet:
Update Post #21 on page 2 shows the gains of the cams after it was fully tuned.
Nice TQ & low-end gains. From the looks of the graphs, can we deduce that the stage-one cams are actually less aggressive than stock??
Judging by how they sound at idle, I think they are definitely more aggressive then stock. Once we are done tuning I am fairly confident that the car is going to make a lot more power. There is still a lot left on the table in terms of boost and timing.
Mods:
-Turbotrix Evo X pipe kit with CAI
-Turbotrix 3" Exhaust
-Turbotrix Divided o2 eliminator
-AGP FMIC
-Kelford Stage 1 cams
-Walbro 255 FP
-850cc injectors
-ACT HD clutch
-Ecutek tune
-AGP FMIC
-Walbro 255 FP
-850cc injectors
-ACT HD clutch
-Ecutek tune
Nice. Looking forward to seeing the results of the tune. I just thought that usually cams will trade you some low-end torque for upper end HP. If you're seeing an increase across the board, that's awesome.
