FP Red 411whp/365wtq DG Tuned!
We had the pleasure of taking on a beautiful Evo X GSR this week for some big work. Let me start off by saying the customer had everything needed for all the installations. All gaskets,parts, and fluids were provided which made everything go nice and smooth. Now onto the parts/dyno sheets/video!
Mods:
FP Red Turbo (ported)
Cosworth MX1 Cams
Hks Waste Gate Actuator
Hks Turbo Outlet Pipe
Hks IC
Hks Upper and Lower IC Piping
Hks Intake
Hks Recirculated bov
Ultimate Racing o2 Eliminator Down pipe
Hks Test-Pipe
Hks High Power Dual Catback
255 Fuel Pump
800 C.C Injectors
Ams Fuel Rail
S.S Fuel Lines
Hks Evc
Act Clutch/Flywheel
Works Shifter Bushings
Tune Software:
Ecuflash
Evoscan
Tuner:
Charlie
Pete
All tuning done on 93octane/pump gas
![](http://img32.imageshack.us/img32/4519/fpredx.jpg)
![](http://img34.imageshack.us/img34/1382/psib.jpg)
VIDEO: http://www.youtube.com/watch?v=GMs6Vx7jwZU
The right Part combination and the right tune makes consistent and great results. This evo x not only beat our evo x by a few whp but it is also the highest whp evo x we have tuned on our dyno. The car is absolutely a blast to drive reaching full spool by 4,300 rpm and making over 400whp to 7,000rpm. The torque curve is also nice and smooth and boost spikes 26.5psi then slowly tapers to 24psi at 7,000rpm with this ported fp red turbo and hks waste gate actuator.
Mods:
Cosworth MX1 Cams
Hks IC
Hks Intake
Hks Test-Pipe
255 Fuel Pump
800 C.C Injectors
Ams Fuel Rail
S.S Fuel Lines
Hks Evc
Act Clutch/Flywheel
Tune Software:
Ecuflash
Evoscan
Tuner:
Charlie
Pete
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
Yes, We can make these cams idle like stock. I personally like a little lope. If the customer asks for a smooth idle it is not a problem
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Thanks!
Actually if I remember correctly, duty cycles were around 85-90%. Could have pushed a little more but this is a daily driven car. Stock bottom end etc. This is the highest whp evo x on our dyno and the customer was talking about doing a stroker motor within the next month or 2.
Well on the dyno is one thing. You basically feel how the car comes on more by hearing/feeling how it revs up. You do not really get a feel for power on the dyno by actual force.
We do not go and simulate 1-4 gear pulls on the road. Some light cruising to dial in any drive-ability and 1 or 2 3rd gear pulls to view a few logs to see if anything changes from being on the dyno. The car does feel absolutely sick though!
Other than that all your hard work/time/effort for the past few days and you hand the keys over and let the customer have all the fun!![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
These are the same stock plugs that came in the car from the factory with over 10,000 miles on them. Same gap etc everything. They have never been out of the car.
We have never had a break up/mis-fire with the stock plugs/coils up to 30psi so far.
The stock ignition system/plugs are proving to work flawlessly so far.
