EFI Logics tuned EVO X FP Red w/ AMS boltons - 25psi pump gas
#46
Congrats Louis! Very impressive numbers indeed!
My friend is torn between getting a fp red or doing cams. Its still up in the air seeing as the gains between both separate, are phenominal gains!
As for a dyno, I prefer a dyno dynamics. But I don't use the dyno for these irrelevant numbers, as every dyno reads different and a dyno is merely a tuning tool, not give you an exact number of what your car is making. I use a dyno dynamics because it has a great load bearing dyno that can replicate a real load on your car like the street, giving you a better chance of tuning your car safely and more precise for the track or street. Numbers is nothing but that, a meaningless bragging right and just a number, (not trying to poke at you or dog you Louis), but the real bragging right is in the trap speed and et!
Congrats on the new found power and big props to EFI on a great, safe, reliable tune for a fellow car enthusiast!
Dan
Dan
Should be interesting to see the different numbers and gains on the dynos.
#47
Yes Dan im torn between cams or fp red. I put down 309hp on a dyno dynamics with just full tbe exhaust and a cone filter no other mods @ 23psi. I should make 400 with a fp red and remaining bolt ons! The fp is only 1400 and no one will know you upgraded the turbo but the cams do sound sick! Excellent numbers and good luck with your setup!
#48
Full TBE
IC
IC Piping
Intake
800cc Injectors
FP Red
Cams
and you can't forget about the DG Tune....
P.S: The cams can be tuned to idle like stock...
#49
As I found out recently, unless you are willing to set your rev limiter to 8500 and risk valve float, mesuring trap speeds is tricky at best since you need to shift to 5th just as you reach the finish line. 4th gear is just too short on these cars and while it might be just enough for a stock turbo to rev out at the traps, an upgraded turbo puts you right in that dead zone where you are coasting at 8000 rpm across the line.
Jimmy, as we talked about it before, I would do the cams first, and you are in great hands with DG with anything you need done.
To the OP, I LOL'd out loud when you made the comment about making ridiculous numbers on some vendors dyno!
Dan
#50
Not necessarily. For example, if you have a good set of valve springs (I had gsc beehives with stock retainers and cosworth m2's) and a evo 8 4th gear, you should have zero problems. Just ask the buschur guys or anyone trapping low 130mph. They never touch 5th gear, nor have issues with valve float. Not to mention, on my setup with a stock turbo, I revved my car consistantly to 8700rpm with just those gsc beehives and stock retainers, valves, and guides, just had cams.
Dan
Dan
#51
To the OP, intake temps consistently above 100* F will make the Evo pull timing no matter what you put in the timing map. There is a temp vs. timing table that makes the Evo pull timing whenever the intake temps are always above 100* F. So it is a very good idea to invest in a good quality aftermarket IC to keep intake temps at bay.
To others, this debate over dynos is so lame. This dyno reads low vs. that dyno reads high is a bunch of BS. IMO, only ricers make that argument. If you are really prefromance oriented, you will use the same dyno for ALL your testing and look at the gains regardless of peak numbers. That is exactly what the OP did. He reported the gains and still some posted how they got 370 hp on a dynojet with a stock turbo. BFD. Different dyno, different results, different Evo, different mods. It means absolutely nothing. I hate these lame *** arguments. They spoil good threads like this one.
If I was king of the world, I will make dynos that will only report GAINS and not maximum numbers. I do not give a rat's *** if a car makes 500 hp on a dyno w/o knowing the baseline that the car started with.
#53
158awhp later, the car is a whole new animal. I haven't been beat, yet! (On closed course environments of course).
- Louis
#54
So you car ran 40whp less then mine did stock and i was on a dynojet. So that put you at 400whp on my dyno. This makes me very happy because i was 400whp on 23psi with my red, in p&p'd, externally gated, mbc, + water/meth, and a ams fmic. So i deffinatly see 400whp on 23-24psi happening for me.
#57
They don't have a high reading dyno....and the blouch didn't hit 440 whp on there dyno. They did a blouch with a similair set-up as the red and made very similair numbers...I think a couple HP less.
On other dynos though these would be over 440whp though.
#58
Just wanted to report in that I got beat last night, and it was a solid loss, too. Like 3-4 cars and losing ground over 100.
EVO IX, FP Green, 26psi, cams, FMIC, twin disc and supporting mods. He ran 11.8/11.9 at 119mph.
Back to the drawring board!
- Louis
- Louis
#60
Sounds like someone tried to hustle you!
