Bone stock X w/Dynojet CMD 327hp/345tq
Do you have the uncorrected dyno chart? I'm assuming you're around Vegas which has an elevation of ~2000ft. From my research, the correction factor built into the dynos is for NA engines, which does not work for FI cars. Basically, it over inflates the number for FI cars, which explains the ~270whp stock reading.
Thanks for the explaination I always assumed "Bone" stock meant how it came off the showroom floor, but I didn't know what the CMD thing was either. Title is a little misleading I guess for those who don't know what CMD is - most people would probably write "bone stock with only a tune". Thanks.
Gotcha. The CMD product release with special pricing for Evo M members was posted in the vendor for sale area. It's over here: https://www.evolutionm.net/forums/ev...ner-evo-x.html
However, the changes in A/F ratio are made directly at the injector by pulsewidth, rather than by skewing what the ECU sees from the sensors. We read and can limit was the MAF and MAP send back to the ECU, which can keep the car from going into limp mode due to overboosting. We also have complete control over the wastegate solenoid and can modify it's duty cycle to control the boost to whatever level we want within the limits of the turbo.
The CMD does give you the ability to monitor and log it's sensors though, as well as do tuning yourself. Down the road, we will also be able to couple it with our WideBand 2 device and give it closed loop control of A/F based on our own O2 sensor. No other piggy back currently gives this capability, and you can't do it with a flash.
Timing we plan to add down the road with the addition of our Ignition 2 module currently in developement. It will connect to one of the CAN ports on the CMD and interface through that.
As the CMD was designed to fit multiple vehicles with different configurations in the firmware, MIVEC, rev limits and other vehicle specific parameters will not be able to be modified. Air/fuel ratio, boost and MAP/MAF clamping is what the unit offers for the EvoX.
Agreed. Those numbers seem on par with what other good tuners are making. I had my Evo X MR (Daily Driver) tuned by Sean at Iveytune on his DynoJet will ONLY an HKS Drop-In and a Cobb AccessPORT, He was able to conservatively make 309AWHP/292AWTQ and I think that was at 24psi.
The dyno graphs shown are on a bone stock - not otherwise tuned X. This is without MIVEC changes. These graphs represent what the CMD has the capability to do. Given the price point, we feel it's a very good bang-for-the-buck.
In the near future, we will be adding an intake and exhaust to our X, and plan to show those dyno graphs as well.
