Bone stock X w/Dynojet CMD 327hp/345tq
#32
The dyno graphs shown are on a bone stock - not otherwise tuned X. This is without MIVEC changes. These graphs represent what the CMD has the capability to do. Given the price point, we feel it's a very good bang-for-the-buck.
In the near future, we will be adding an intake and exhaust to our X, and plan to show those dyno graphs as well.
#33
Mivec would give a ton of extra torque in the middle, but if I am reading into your post right and you are worried about knocksum up top as well, Evoscan can still log the car and put potential buyers minds to rest. Most flash based cars taper a bit more power up top, because the increase over stock boost means a reduction in high RPM timing.
I think you know the answer to your own question, Mr. Kent.
#35
If you meant something else, please reiterate your question.
#37
There are basic maps available on our website for the Evo X. These are understandably conservative. Plug-and-play gains are still good and provide a seat-of-the-pants increase, but to really tune it in and extract all the power available from any one car, custom tuning is advised.
#38
Product update - The CMD can now display and log wideband readings in it's Master Control Center software when used in conjunction with our WB2 wideband device. The next addition to the software/firmware will be the ability to AutoTune - or have closed loop control on the WB2 wideband data.
#39
Timing we plan to add down the road with the addition of our Ignition 2 module currently in developement. It will connect to one of the CAN ports on the CMD and interface through that.
As the CMD was designed to fit multiple vehicles with different configurations in the firmware, MIVEC, rev limits and other vehicle specific parameters will not be able to be modified. Air/fuel ratio, boost and MAP/MAF clamping is what the unit offers for the EvoX.
Are you logging knock to see if the car is pulling timing up top? If not, then I would suggest that you do and see the impact of the lean AFR and higher boost on the timing curve.
#40
Actually, you can midify closed loop AFR with a flash. A lot of us run closed loop AFR at 15.2-15.4:1. Ofcousre, we remove the cat and run an AFR wideband for safety. We have been doing it for a long long time. All you have to do is modify the open loop/closed loop tables.
#41
So you are able to lean out the AFR, add boost, but CANNOT lower the timing. On 91 octane gas I can GUARANTEE you that the car will knock. There is no way that you can run 11:1 AFR, add boost and run the same stock timing that the Evo X has.
Gexxer - are you noticing any knock on your car?
In the coming months, we will also be offering the AutoTune feature for the CMD's, where we will be able to close-loop based on our WideBand 2 and a target A/F table in the CMD itself.
voidhawk
13
Jul 12, 2013 09:07 PM
Ender179
11
Aug 9, 2009 02:25 PM
fevo
Future Lancer / Evo Models
51
Dec 13, 2006 11:09 AM
