JESTR does it again! 330hp/340tq (stock evo x)
#46
Say whatever you like but that can not be true.
I do not know how you guys calculate the power out there in the States, but c'mon, be reasonable!
IF the factory claims the car has 295HP which would be about 230WHP(am I right?) how in the world you could get a ONE HUNDRED HP just from god damn drop-in?!
Pure Sci-fi to me.
My car is bone stock and slightly tuned. It shows 333HP at the flywheel.
AT THE FLYWHEEL.
I know it is possible to make it up to 350HP which would be around 280WHP.
I am going to replace inlet, UICP, exhaust and I am hoping for 390-410HP which would make about 320-330WHP.
Here in Poland, we recently learned that the graph is for nothing - just to make you feel better.
If you disagree, take two cars dynoed on different dynos and check it for yourself.
Last but not least - it is good to see that the owner is happy.
And, eventually, that is the most important thing.
Pure Sci-fi to me.
AT THE FLYWHEEL.
#47
How far you can safely turn up the boost is directly related to what fuel you are running. In my mind it is the fuel that is adding power, the boost is sort of a 'supporting mod' that goes with the fuel.
I'll be the first to say that I'm a novice when it comes to motors, so I may not be thinking about it 100% right.
A motor needs more air that will be ignited to make more power. Not the amount or grade of the fuel. You can ride around on 100 octane fuel with 1000cc injectors all day and not see an ounce of whp. Read up on fuel injected motors.
A car needs O2 that can burn in order to make horsepower. On the same vein, the fuel is required in order to burn that O2. The Evo X's stock fuel injectors are more than big enough to handle the extra air going into the engine from turning up the boost on the stock turbo.
#48
Pure Sci-fi to me.
Pure Sci-fi to me.
The big whp increase came from the tuning.
-M
#49
You could also try running 29psi on low octane pump gas and watch your motor knock itself to death. I'd be willing to believe that increased air volume and fuel are both required to make more power but you seem to be implying that it's all about boost. That's not correct.
#50
I'm stating that fuel alone will never make more power. Air will - up to the point where you have uncontrolled burning (i.e. detonation or preignition).
#51
#52
If he's running 93oct then I'd believe it. A well tuned X with basic bolt-ons will do 340 on MAP's Dynojet.
We all like to believe that our supporting bolt-ons add a lot to peak power, but they don't. Some improve the curve (cams), others make the power more consistent (fmic, radiator), others improve throttle response (uicp/licp, intake, throttle body), but peak power isn't helped a whole lot without major upgrades (fuel, turbo).
I've wasted a lot of money grabbing 1-2 hp gains. <shrug>
Getting some real world trap speeds from a quarter mile run would also confirm power levels, but likely a DynoJet with an average of 20% losses would have to trap around 111 mph and deliver around 395 crank HP if it really was making a 330 whp on such a dyno. It's probably not impossible with perfect tuning but likely isn't quite that good.
Looks like this tune has really improved how the car uses the mostly stock components, adding furter bolt-ons and tuning for them should net even better gains down the road.
#54
It takes quite a bump in power to actually feel the difference when you go out to drive the car. The real question is whether the parts are worth the money. Obviously if you are building a 500hp car then you need all of supporting mods. With a stock turbo half of the mods that people do just aren't worth the money, imo. Anyone who can feel the difference of an fmic upgrade has a finely tuned butt dyno, indeed.
#55
But tell me something - how to get 100WHP from tuning on a full-stock car, without replacing restrictive exhaust, UICP, inlet line (and hey, why ppl do that at all?).
Something is not right here...
Can you imagine how much more air and fuel you need to supply for those abt. 150HP at the flywheel???
Sorry, but I still do not consider it possible.
#56
I think everything in this thread is getting read into way to much. IMO I dont go to the dyno to see how much power I can make or what it will peak at. If the graph is smooth and the car is not running like **** I would be happy with 300/300. Its not all about WHP its about the smoothness of the graph, how it holds power, and all in all if the owner of the car is happy. Thats all.
#57
OK.
#58
Also, if you don't change the exhaust, it will quickly become a bottleneck and hamper volumetric efficiency which will cause your car to peek out in whp and produce no more power.
#59
You will pick up the bulk of your power from a tune, but even the tune requires turning up the boost. You won't get much of anything with a tune and stock boost.
#60
