Harmon Motive intake for Evo X tuned by TTP!
Preston had contacted us via phone regarding getting his new Evo X GSR tuned at TTP. His only modification at the time of the call was a Harmon Motive Intake system and a CEL light. Concerned with the CEL code for system to lean bank 1 we advised him that conical intakes on a enlarged maf housing need to be retuned immediately after install. The enlarged housing will reduce the MAF reading at idle which will cause short term fuel trims to drift into -% which will carry over to the long term fuel trims and can affect not only idle and cruise, but also wide open throttle.
Preston brought his car in and we put it on the lift to swap out his downpipe and install our wideband sensor for precise measurement on the dyno. Once we got the rollers spinning, boost peaked at 24.1psi on the intake and DP and car put down 280-288whp with non-linear delivery.
Once the car was tuned with our MIVEC mapping, ignition timing, boost and fueling we were able to extract 326whp with a tire spinning 344tq to the wheels.
Quartermile testing revealed in third and 4th gear power would peak in the 333-338whp range in non single gear pulls. Car is expected to trap 109-110mph based on our testing.
Cosworth drop in
HKS drop-in
Works Drop-in
AEM
AGP
AMS
HKS
Injen
ETS
All of them made the trims go positive. When an intake is installed on an Evo X the trims go positive after the car is driven for a while. The AFR then becomes RICHER and not leaner as you suggested.
Maybe the Harman intake is different and it makes the trims go negative. I have not tested that intake. In ALL the other ones that i have tested the trims were positive. I make it a point to drive Evo Xs with intakes at a steady speed for at least 30 minutes to see where the cruise trims end up. the trims ALWAYS end up positive. Not once have I logged the trims on an Evo X with an intake at steady speed and had the trims go negative.
Again, maybe this intake is different, but I do not think so.
TTP Engineering
Mar 19, 2010 05:15 AM
TTP Engineering
Oct 29, 2009 10:48 PM
TTP Engineering
Sep 4, 2009 07:48 AM
TTP Engineering
Evo X Dyno Results
45
Jun 27, 2009 03:32 PM
TTP Engineering
Evo X Dyno Results
29
Jun 1, 2009 04:37 PM
