Top Level + FpRed + Pumpgas = 477hp
#62
what afr`s you stay on?
murlo is right, i got similar built than murlo with the add on of intake rev 3 mani and 64mm throttle body along with tubular manifold and i saw 484hp at 34 psi bu i ran out of my single walbro. now i run 30 psi and 460hp. also my toque at 34psi was 453 with the kelfords, they do make more tq than the BC`s period...
not a lot has been done to the timing though...
just curious about the afrs
#63
#66
95.5mph to the 1/8th------------------- thumbs up!
2.0 60ft ------------------------------------ thumbs down!
bov hose popping off in 4th gear ---- double thumbs down!
still cracked 11's on the pass----------- thumbs back up!
I'll post the slip when I get a chance.
A little practice and I think we'll have one heck of a driver here!!
#67
A little bit more getting used to this car and this thing will be ripping!!
We'll lower the 2-step a tad and see if that will get her to grip a little harder.
NINJA EDIT::
,,, and we'll wait more than 5minutes between passes to let her cool down--- heheheee
E-SPEC INDUSTRIES
254
Oct 26, 2016 11:46 AM
E-SPEC INDUSTRIES
Evo X Dyno Results
16
Sep 6, 2014 10:12 PM
E-Spec@Tach Motor Works
Evo X Dyno Results
509
Nov 21, 2011 11:44 AM
May 23, 2011 06:29 PM
