349whp 316wtq Ivey Tuned
#49
Hahahahaha well because of you....ummmm yea, so I just want it to be known, because of you I will be spending $6,930, so yea f u very much hahahahahaha. Once I held that fp black in my hand I knew it had to be mine!!!
#57
Are you referring to the original numbers he posted before they realized he had a faulty MAF or the most current numbers Ivey posted after they replaced the MAF? His new torque #'s are right on track with the results I got with similar mods/tuning. The only variance I really see is from which weather correction each DJ shop is using. SAE shops are getting around 335whp/335wtq while STD shops are getting around 350whp/350wtq which is technically the same power output, just different correction format. Without upgraded cams, it seems to be about as much power up top as you can really squeeze out of the average bolt-on X. I drove one after I tuned it and 350/350 is a very smooth and nice setup on the X for the money it takes to get there.
#58
Oh yes sirrrr...!
mct9891
34
Jan 29, 2015 10:31 AM
EVO X 6950
Nov 15, 2010 11:16 PM
