Mellon Tuning - James EvoX MR SST Auto - 93 octane @ 25 psi
EVO X 2008 USDM
MR SST Auto Tranny
AEM WB02
93 octane @ 25 psi
3" TBE Test
AMS intake ur uicp
295hp/332tq
EVO X 2008 USDM
MR SST Auto Tranny
AEM WB02
93 octane @ 25 psi
3" TBE Test
AMS intake ur uicp
295hp/332tq
Hi Gary,
Could you tell me why the power curve is not smooth all the way to redline?
I have just had a tune done to my SST evo X, which also has a kink (though its not as "flat as yours" it has a slightly higher peak and trough at the 4-4.5k rpm range.
When I posted this on the forum, it was decried by a number of ppl as the curve was not smooth.
I am new to this, any information will be welcome.
FE.
FE.
That hump and valley is actually a problem with the way the SST RPM can be sometimes and will show up in this software like that because the RPM data is not "linear" like a 5spd, it also means that torque peak number is artificial...
I've seen torque peak numbers +40 from actual from this occurrence.
To confirm, on a real dyno, this error in the SST RPM reading is not an issue? i.e any spikes on the graph are real and need to smoothened out asap.
Thanks.
FE
Gary@MellonRacing
Dec 20, 2011 01:07 PM
Gary@MellonRacing
May 14, 2011 04:59 AM
