AGP Turbo Kit with Zeta 2.8 505whp
Never heard of it before either. Found this on their website:
A work in progress since early 2008, the Zeta line of turbochargers is finally here featuring 5-axis CNC machined billet 7075 aluminum compressor wheels. Our smallest offering, version 2.8 with flow capabilities of 50lbs/min, is a perfect match for power levels between 400-500 horsepower. The Zeta series turbos are only available with the Dual Ball Bearing center housing.
Compressor Specs:
- AGP Cast T04E ported shroud housing 4" inlet 2" outlet
- AGP billet 7075 aluminum compressor wheel 50lbs/min
Turbine Specs:
- AGP Cast T31 4 bolt outlet T3 turbine housing available in .48, .63, and .82 A/R ratios
- AGP Cast 3" V band outlet twin scroll T3 housing available in .55 and .75 A/R ratios
- AGP Cast 57mm turbine wheel
Compressor Specs:
Turbine Specs:
AGP makes top notch products, great customer service. You will not be dissapointed with anything you purchase from them. I currently own in addtion to my 2012 mr x a 2004 dodge srt 4. All AGP products on the srt, AGP Delta 44 with all supporting AGP mods, including a mail order tune from AGP that is spot on. Been running my stock 2.4 with 387/444 for four years now with Zero Issues with any AGP products.
