2008 GSR - Stock Turbo - Moore Automotive Tuned - 375hp/402tq
2008 Evo X GSR
Gas: 93 Octane
Mods: Moore Automotive Velocity Stack Intake
Moore Automotive 2.5" Upper Intercooler Pipe
Moore Automotive 2.75" Lower Intercooler Pipe
ETS 4" Intercooler
ATP 3" Open Dump Downpipe
Ultimate Racing Test Pipe
Ultimate Racing Cat-Back Exhaust
Pierburg BCS - Peaks 28.5psi - tapers to 17
~Chris@MooreAutomotive
Tuner/Master Technician
Gas: 93 Octane
ETS 4" Intercooler
in oz this would be called a disneyland dyno. i thought once over 25 psi you would be just pushing hot air. as long as your happy thats all that matters. with that wheel hp no excuse for not running 11 on the 1/4.
Oz evox, 11 withthose numbers? Are you on crack? Vegetax just did that but running e85, how can you possibly say thats 11 with 375? You must be a tremendous driver my friend. Nice stuff btw.
The stock turbo doesn't hold 28psi for very long before it tapers due to the small turbine housing, I run that much on every stock turbo setup that wants to push it, including my own. I haven't had any one of them come back with problems and it's obviously making power.
You're absolutely right, this is capable of running 11's. Check out this thread with another customer of mine I tuned, stock turbo, only bolt-on's, and he's running 11's http://www.evoxforums.com/forums/showthread.php?t=68811
So, because I know how to tune an X to make good power, and I'm not a big name, you guys want to say my dyno is inflated. Guess what, I can't change anything to make our dyno read higher or lower like you can with a Mustang. It reads what it reads and that's why it's the industry standard.
not trying to rubbish any ones tuning abilities or numbers.but to many times i see massive dyno numbers that must be to inflated. i think an honest baseline for these cars are around 220-230 whp. from there its simple maths once tuned with decent parts. here locally a stock tuned x would be in the low 300 whp dyno dynamics and will run if driven well a low 12on the 1/4. thats why i said with these numbers it should easly crack 11,s.
