EnglishRacing/ETS Drag X Season 2 - 1033/731 Gen One 7285
UPDATE -
New season brings changes to every racecar, the Drag X had been quietly being upgraded over the winter in preparation for the 2015 season. Last year we started with a stout platform based on the following -
The Build -
EnglishRacing Aluminum rod 2.0L Sleeved motor
86.5mm bore
Wiseco 9:1 Pistons
R&R Aluminum rods
ETS 7285 twin scroll turbo kit with 1.28 housing
ETS 4" FMIC
GSC S2x camshaft set
GSC 1mm valves
GSC valvesprings
Fuel Injector Clinic 2150s
EnglishRacing Double pumper kit with dual 044s
EnglishRacing Ultra Race Port cylinder head
Motec M800 PnP ECU
E98 fuel
GRAF Autohaus 5 speed Dogbox
Competition Clutch Triple disc clutch
Additional -
EnglishRacing Little Brake kit (front and back)
15x8 wheels
Mickey Thompson 26x10.50-15 ET Street DOT tires
EnglishRacing 10 point cage
AC delete
EnglishRacing prototype ACD control
Evo IX rear diff (AYC delete)
EnglishRacing Front Aero kit and undertray
Over the winter the car lost over 400lbs which made a HUGE difference in parts reliability. After getting the launch dialed yesterday at IFO Seattle Lucas was able to reset the Evo X stock chassis record with the following -
Thanks to all of our Sponsors, crew, and all those that have helped make this car possible. It will be at the Shootout in competition for those attending that want to get a closer look at it.
Aaron
The Build -
86.5mm bore
Wiseco 9:1 Pistons
R&R Aluminum rods
ETS 4" FMIC
GSC 1mm valves
GSC valvesprings
Motec M800 PnP ECU
E98 fuel
Additional -
15x8 wheels
AC delete
Aaron
working on the ACD control still so there is a little bit of FWD to fight as well as this was on some E.T. Streets so they werent even real slicks. The 1.54 is a combo of the ACD and traction versus not enough nitrous
2850ish without driver, with driver right around 3040
No one ever seems to run nitrous on evo's and I really wanted to run a 75-100 wet shot on a window switch on my car right now and destroy my diff
Ah, i see. So your current best pass was without nitrous though? Just curious, what are you running, small 75 wet kit or something?
I agree, we need to get some 26" M&Hs on it and get nuts. Watching the video it seems as though its time to throw some suspension under the car to get it to keep from wanting to plane after the shift. Doesnt help front traction at all.
