DVD Hack for the MMCS
#227
Quick question. On my bro's GTS it is not working. We get this message:
Selecting [next] will write the authentication code in the version up key and the key will become available only with this system. We hit next but we get this message: "VERSION UP KEY WHICH CAME WITH THE MAP DISK CANNOT BE DETECTED. CHECK IF THE KEY IS INSERTED CORRECTLY"
Any ideas as to what the problem is???
#228
Please indulge me:
Can someone please post the link to the definitive file for evo x MR? Is there now one universal file or is it still program version dependent?
Just burn ISO image and put it in system? No other commands,buttons to push?
I am very grateful.\
Thanks
Can the MR be different? I don't get any info when i push nav/set and touch the info button! Has anyone done this on a MR?
Thanks
#229
I just figured out I need to hold down nav/set butoons for 3 seconds to get the right screen.
I have loader 261um and 30.97, so it is not the same (others are 30.94)!
No luck. Burnt using Iso recorder and image burn programs on CD-R 4x on 2 different computers. When I put disc in says checking disc and then the message disappears and that's it: nothing more. No message behind any screens, etc
Any ideas?
Thanks
Any ideas?
Thanks
#230
Any ideas?
Any ideas?
#232
#234
#235
Heh..
Read this thread - it'll tell you how to unlock your hard-drive, and copy the file off..
http://www.mitsubishiforum.com/m_208034/tm.htm
atb.
O.
This'd be a hell of a lot easier if there was someone in the Belfast area.. :/
atb.
O.
#236
Hmm..
http://cgi.ebay.com/ebaymotors/_Manu...em120280102539
I think, due to this, I'm going to have to brand any future releases.
atb.
O.
atb.
O.
#238
Heh.. :$
Someone mentioned they'd seen my patch floating oround on ebay - I might've jumped the gun on it being this guy then..
Hmm - I thought the bypass switch didn't work ?
atb.
O.
