Removing plastic piece behind rear headrest?
Old Apr 22, 2008 | 08:28 AM
logonzojls's Avatar
Does anyone know how to remove this? I plan on throwing some tweeters in there but have so far been unable to remove thi.( Feel like somethings going to break.)
Old Apr 22, 2008 | 10:25 AM
DirectorSe7en's Avatar
Chainsaw?
Old Apr 22, 2008 | 10:33 AM
logonzojls's Avatar
What size blade do you think i should use? 18" or 26"?
lol
Old Jan 20, 2013 | 04:03 PM
Mike_evo's Avatar
Just pull the back circles out and you're done
Old Jan 20, 2013 | 04:50 PM
Johnr352's Avatar
If you do break it, I have an extra you can have.
Old Jan 22, 2013 | 12:54 PM
SmallSoldier's Avatar
Take the backseat out... You need to take first the bottom part of the seat (just pull upwards on it, there are 2 clips near the middle of each sitting position where the seat ends... Then, you will need a 14mm socket to take 2 bolts that hold the upper part of the seat... once those are out, you need to pull upwards because there are 2 metal hooks that hold the backrest of the seat
Once the seat is out, you will find 2 plastic clips... take those 2 out and finally you just need to tap the plastic piece upwards (it is hold by the "white type" clips)... If I remember correctly, there are 5 of those
It is not that hard, but a bit time consuming
Regards,
SS
bvliz
Nov 14, 2016 01:18 PM
just a neon
Evo X How Tos / Installations
Aug 21, 2008 08:15 PM
Ink
12
Jul 25, 2006 06:59 AM
wprettyboy
53
Nov 15, 2004 11:36 PM
Quick Reply: Removing plastic piece behind rear headrest?
