Navigation change to boost gauge??
Old Dec 9, 2008 | 02:19 PM
rogue's Avatar
You guys most likely can buy the part and hook it up to your nav. I plan to do this when I have a chance. Also, you can watch external video on your NAV, but while driving is up in the air as I don't know if the DVD hack also took care of it. From what I have read, it has not.
Old Dec 9, 2008 | 06:22 PM
stokEd's Avatar
Unstoked.
Originally Posted by xPRimNT
As of now, there is no Aux-In-Motion patch.
What a bummer. I didn't know the AUX-in-motion was a problem until recently. I read through the DVD hack thread and got all excited. I was really hoping to run the Camp2 through the OEM Navi--mostly to avoid having gauges on display everywhere.
Until that is discovered, you're stuck with having to get an aftermarket display.
It's too bad I can't wait until things get worked out; I've heard a lot of good things about the OEM Navi.
Old Dec 9, 2008 | 06:30 PM
Cyp's Avatar
Cyp
I have the navi but no rockford fosgate system and no imput auxiliary. Is there a thread that shows you how to add the factory auxiliary imputs?
Old Jun 24, 2009 | 10:57 AM
silverboost's Avatar
I went to a car stereo place and they said that they can install a part ($300 installed) that will give you both aux in motion and dvd in motion. Anyone have anymore info on that part?
I'm kindof okay with $300 for the part and $700 for the guages. I'm trying to keep the car as stock looking as possible, so its worth it for me.
Old Jun 24, 2009 | 11:09 AM
Stellar24's Avatar
If you dont mind cutting/splicing wires, I am pretty sure you can put a switch inline with the GPS navigation signal. If you switch it off, the car doesn't know its moving and the AUX will continue to work. However, you obviously cannot use the Nav with the switch off. Search for it and you might find it. This was the original DVD in motion fix before the hack. Also, the DVD in motion hack does not support AUX in motion.
Old Jun 24, 2009 | 12:02 PM
goofygrin's Avatar
This is my project that I'm working on....
http://www.youtube.com/watch?v=oe08eiR1jX0
You do have to splice some wires, have a tactrix cable and a computer with EvoScan on it. All less than $1k ($300 part + $700 for the hks part).
Old Jun 24, 2009 | 11:19 PM
dotkong's Avatar
build a carputer, you'll have a boost gauge and a lot more.
Old Jun 25, 2009 | 09:41 AM
stock looking is the goal. thats why I wanna use the navi so I don't have to add other gauges.
Old Jun 25, 2009 | 09:45 AM
dotkong's Avatar
there is a way to use the stock screen with a carputer, just got to some centrafuse forums, but its probably not worth the trouble just though i'd throw it out there
Old Jun 25, 2009 | 10:26 AM
goofygrin's Avatar
I'm using the stock screen through the composite input (really the backup camera input).
Old Jun 25, 2009 | 10:39 AM
I'm in the same boat. I have laptops setting around that I could use, but no aux video in motion. But if you would shoot me some links. I work in the computer field so I have a few lol.
So does that mean it only works when in reverse? Got a link to any write ups on how to do it.
Pretty positive that they found this doesn't work on some other forum. Can anyone confirm on the evo x?
Old Jun 25, 2009 | 11:54 AM
goofygrin's Avatar
I wired in a switch to make the nav think it's in reverse... so it's whenever I want.
The backup camera pinout is out there (look for outlander sites). The backup signal is pretty easy to find if you have a multimeter. It's on the top left connector on the back of the MMCS on a purple and yellow wire if I remember right.
Old Jun 26, 2009 | 09:54 AM
THATS AWSOME. So I guess I gotta start looking around for either the stuff to make gauges on a carputer or start looking for one of the 2 gauge sets that are pre-done.
Thanks.
Old Oct 10, 2009 | 06:15 PM
Adam123's Avatar
even my moms gts has the red yellow white
Old Oct 10, 2009 | 06:38 PM
MuLo_MS's Avatar
That is sick
Quick Reply: Navigation change to boost gauge??
