Navigation change to boost gauge??
HKS camp II http://www.nengun.com/hks/camp-2
You should have rca video in if you have the tech pkg. it is located by the audio in. i am assuming you would also need to do a mod to have the display show while in drive.
the MR comes with the yellow input.
The GSR has the input, but no jack. There's a thread somewhere on here with the diagram of how/where you need to wire it into to get the yellow video jack.
If you go with the HKS, then you could just wire it in behind the dash for a clean install. Unfortunately, when you switch over to AUX, you'll lose your audio... and I'm not sure if aux video works when driving (not sure if the DVD hack clears this too).
damn! $2000 and i can't get HKS camp 2 on my navi. mitsubishi sucks for that one. i'm definitely not going to go aftermarket, someone has to come up with a hack for it eventually. with our luck, by then the evo xii will be out...
