Error code U0184
Error code U0184
I figure I would ask here since it has something to do with the radio. With my recent tune the car started throwing error code U0184. It shows "AIRBAG" on the Cobb AP. However, it's universal for "Lost Communication with Radio".
Here's the thing, I've never messed with the factory Nav/Radio. Any of you stereo guru's every seen this code? If so, how did you go about remedying the code?
I didn't update this thread for awhile...however, the issues I had were with a bad aftermarket BOV. That issue was solved a long time ago. However, the "airbag" error code still lingers.
I also have this code and never goes away after clearing it many times with my AP... I did change the head unit to a kenwood dnx6140.. Last time I was messing around with the radio, I took the radio off. Before you take off the head unit, where the airbag/passenger warning light just below the deck has a little sensor strip.. I was wondering if that has anything to do with this code since it is unplugged...
I also had this after changing head units. It has no effect on the car, and doesn't have any dash indicator, so leave it. Apparently the process to clear it is stupid and complicated, so why bother.
Mystykalbaby
Jan 26, 2015 01:23 PM
