Greddy Infometer Touch
I just got my Infometer Touch from EVASIVE and it's SWEEEEET!!
You can find it here:
http://www.evasivemotorsports.com/Me...REDDY-16001604
Notes:
-If you connect the red plugs, you don't need to use the cigarette lighter and can get power off of the OBDII port.
-With the CAN output, the data is in realtime!
(With my S2k and using a similar OBDII infometer, there was a significant delay making the tach features, etc unusable)
-Able to read boost off of my ECU!!!
-Warning alarms work great as shift beeper.
(In order to get a comfortable driving position, the way I have my steering wheel adjusted blocks my tach so this is perfect!)
-With the additional sensors you can order, you can get boost, oil temp, and oil pressure all in one gauge
I know you'll ask for pics so I'll try and get some pics uploaded today when I get home from work. I installed this thing at 5:30 this morning before leaving for work so didn't have much time to take pics
Notes:
Hey guys, after playing with it more I found that the boost output of the CAN interface is 22.3psi.... It's weird but it just pegs at 22.3psi. Luckily, I ordered the boost, oil pressure, and oil temp sensors too. I installed the boost sensor and it's reading great now. I just drove it around the block and noticed that it's showing boost peaks of 27psi. My tuning session showed 24.9psi logged via EVOScan and the mod23 patch. I'm going to continue to see if it's a difference between the ECU output and the vacuum sensor OR, if it's the drastic difference in temps between when I got tuned (90+ degrees) and today's temperature of 70 degrees while taking it for a test drive post-install. The oil sensors I'm going to install later at my next oil change (Bought the sandwich adapter). I'll try and get some pics tomorrow while the sun's out so stay tuned!
You can add three extra sensors. Boost, oil temp, and oil pressure. It looks like it also interfaces with a FCON so if there are extra sensors going to that you could display it on the infometer as well. One not was that if you want to use it as a boost gague, you'll need the external sensor. The CAN output won't go past 22.3 lbs of boost. The gear position display is kinda cool for track vids and data logging but there are too many features! I'm still finding new things I didn't know it could do!
yea i know. i have the boost sensor but i need the separate box for the sensors but i've been really low on cash and plus im trying to get a ruckus next year i should have everything and a tune but we'll see.
I know what you mean.... At first I thought it was just buy some sensors and that's it... But then I found out I had to buy the sensor adapter and harnesses for each sensor! I still think it's a great product though!
