Sony XAV-W1 Install w/JDM Dash Kit, Steering Wheel Controls and 2010 Console
What wires did you have to tap into to get your steering wheel controls to work? I've had the pac hooked up to my Z1 for months...but just ordered the steering wheel controls yesterday.
Do all the buttons work or just volume and channel?
1 Post
Well there's only five buttons, two for volume, two for track, and one for source and they all work. Source turns on my sony deck as well as cycles through sources. I recall two wires from the stock harness get used in addition to power and ground. You run one wire to ground and the other connects to the PAC unit. The instructions detail the wires by colour so it's not to hard.
http://www.pac-audio.com/swixprogram...ehicles&ID=243
1 Post
are these the same same instructions you followed?
Your dash kit looks awesome! I'm thinking of buying one myself, I was wondering if there was anything else I'd need to mount a 2DIN or 1DIN into the car (does it come with all of the necessary brackets, or did you have to buy a METRA?).
Boostin Perform
Evo X Dyno Results
24
Oct 3, 2011 05:59 AM
heavyD
59
Nov 22, 2010 03:00 AM
