My Installation
My Installation
I'll be documenting a bit more. I'm terrible at taking photos while I do ****, however, I will attempt to get some photos of the finished product.
I currently own and operate a 2011 WW MR-T
What I have so far:
CarPC running Centrafuse (Giada i5 machine, 2gb of ram, SSD)
- JoyconEX for steering wheel controls
- Carnetix 2140 (currently dead, on RMA) PSU
- Capacitive Lilliput Touchscreen (wtb jdm dash)
JL Audio XD400/4 for high/mids.
In my opinion, the install itself is creative/meritorious. I have the actual PC mounted in the glovebox, USB piped under drivers seat for the high/mid amp. I extended all of the wires I am using in the factory harness so that I can pull the amp into the backseat a bit and adjust it should I need to. All connections are soldered/heat shrunk (took forever).
I use a lot of the wiring harness components (things like line-in r/l, etc, that aren't in use obviously with a carPC or alternate amp) to send things like remotes, etc, across the vehicle. I am going to be installing some improved low-end (2 12W7s firing inwards in custom fiberglass enclosures) eventually, and I am going to send the RCA to the back using the existing subwoofer wiring, and the remote turn-on as well.
I am going to be installing the low amplifiers directly under the parcel shelf, in the plasti-wall where the fluids/battery are kept, or under the spare tire false floor.
If anyone has any questions about CarPCs, clever installation, etc, let me know.
What I have so far:
you gonna run 2 12W7s? thats crazy! i had 2 in my RSX but it was too much and stuff started falling apart from all the vibration so i took one out and had just one of them running for a few years.
The weight would be my biggest reason not to run 2.
Also, what kind of enclosure were you running? I will be rolling sealed, 1.3ft^3 of volume.
i had a gain knob but i like a lot of bass so i had it half way turned up all the time but it was still too much after a few years. im planning on just putting a 10" in the evo but im still debating it.
jdfrank81
Jun 27, 2012 02:25 PM
