Aftermarket SiriusXM Antenna Location.
Old Jun 15, 2014 | 01:26 PM
Skott2k's Avatar
So I've researched this to no end and I cant find solid evidence one way or the other. I'm deployed so I cant test it myself but I bought an aftermarket double din radio and SiriusXM receiver and I want to install the antenna inside the cabin. I have seen several different locations but I would like to avoid routing it all over the car to test it if possible. Ill attach 2 pics I've found plus I've also heard of it being on the back deck behind the rear seats too. I'm just seeing where people are getting the best results, Thanks for any input.
Attached Thumbnails Aftermarket SiriusXM Antenna Location.-right.jpg   Aftermarket SiriusXM Antenna Location.-sirius.jpg
Old Jun 16, 2014 | 03:11 PM
jakeleclair2000's Avatar
for best results make sure the antenna has a mostly clear view of the sky. My favorite spot to use is in the dash. Behind the radio cavity there is usually some ac vents or a flat spot big enough to stick the antenna. Just be sure to use the sticky metal base that comes with the antenna.
being mounted under plastic is not an issue, as long as there are no other obstructions, which is why far forward in the dash usually works great
Moshi
For Sale - Cars For Sale
Jun 29, 2016 07:50 AM
evoxsteez
Nov 20, 2015 07:15 AM
rmorris003
Jun 19, 2015 04:57 AM
CottageLifer
Outlander Sport
Jun 10, 2015 07:26 AM
stiggysaurus
May 29, 2015 05:15 PM
