Replacing the Lancer Fosgate radio with an Outlander non-nav touch radio
Hi There,
I have a Mitsu Lancer Intense 1.8 B10 (EU GTS-version).
I have the stock Rockford Fosgate Stereo with 6-cd changer (8701A260) and the factory fitted sub in the back and recently bought a Outlander non-navi touch radio (8701A560; I think 2014) which I would like to build in.
Now I understand the 2014 Lancers are fittied with this same radio. The connectors all fit, but if I connect the new radio there is no sound. Also a lot of warnings pop-up on the onboard diagnosesystem.
Can anybody help me out and tell me how I can fix this or why this won't work?
Thanks in advance.
Thanks in advance.
Possibly I found why this will not work. I guess my Stock radio is equiped with a factory amp under the driver seat. Possibly works via CANBUS.
The Outlander radio has a built in amplifier and there does not steer the amp and does not support the CANBUS, giving all the errors.
Can anyone confirm this?
An aftermarket amp is preferred but unless you want to fry it you have to replace all your speakers too. I believe the stock amplified speakers meter out at 1ohm. Most amps operate at 4 ohms, sometimes 2. The decreased resistance will cause an inexpensive amplifier to overheat and possibly short out. The best bet is to check and make sure that it is a high current amplifier and that it is 1 ohm stable. Most amplifiers that are 1 ohm stable are used for a subwoofer applications and have mono output.
1. $100 sub-par 4 channel in $40,000 sports car. Fail
2. You cannot replace the stock amplifier and keep the stock speakers unless you are willing to invest $$$$ and find a company that makes a 1 ohm stable 5 channel amplifier.
The factory amp is nothing to brag about, but as far as i'm aware, there is not another viable option for stock speaker amplification.
The ONLY part you can replace independently in the RF system is the radio. Factory speakers and amp have to stay or go as a unit.
I hate to bump a completely old thread, but im about to do the same thing and wondering if anyone knows anything knew? Part number 8701A560, Just wondering what I would need to hook up to 2010 RF Lancer. Wondering if I would need the navigation install kit even though its a non navi thing, or would my stock stuff all fit?
ALT3REVO
Evo X How Tos / Installations
Feb 12, 2017 02:15 PM
glenn63
Oct 8, 2015 09:26 AM
joey0480
Jan 22, 2014 05:31 AM
osunick
Oct 5, 2010 12:15 PM
