SSS Headlights on non SSS GSR problems
So I recently bought, the SSS headlights for my GSR. I have done the DRL disable mod to get rid of the flickering issue I had. However for some reason my driver side high beam doesnt turn on, my passenger is fine but my driver side doesnt want to work. I have been working with the seller to try and fix this issue but we cant figure out what is wrong. He says that the DRL (middle light in between the projector and turn signal lights) are the high beams so he doesnt know why the high beam is coming from the projector. After some research, I have read that the OEM SSS headlights are in fact bi-xenon lights so the high beam actually should be coming from the projector.
Basically right now everything works fine except for, the DRL lights (middle lights) I'm not sure if these should be working or not, and the driver side high beam.
So I just want to confirm that the OEM SSS headlights are in fact bi-xenon, and what you guys suggest to fix the high beam issue. And also, are the DRL lights (middle lights) supposed to work or not?
Thanks
Thanks
Projectors are bi-xenon. You should hear the shutter activate when the light is activated. The DRL light should only come on if the parking brake is disengaged.
Edit: Looks like I was wrong and they aren't mandated. So on later models is there even a bulb in the center part of the housing? Seems like waste of space now.
The original poster has a Canadian model though, so I believe that is why he has DRLs. There is no DRL after 2010 on the US models.
Evobro19
Dec 9, 2012 06:56 PM
boostinonyou
Jan 27, 2011 09:01 PM
letitroll
Jun 9, 2010 08:54 PM
