Ecutek with ARC upper intercooler pipe lost power??!!!???
Hi all, Car is a JDM EVO X Premium ed (usa MR), mods were kakimoto dual exhaust, ultimate racing resonated test pipe, arc upper ic pipe, Blitz cone airfilter and ecutek.
base numbers were under 300hp flywheel....as soon as the arc intercooler pipe was taken out and replaced with the stock unit we netted a 40hp gain! has anyone heard or experienced this before?
what do u guys think is wrong, is there a conflict in the amount of air flowing that ecutek is restricting the car maybe? I have to be honest and say i have no clue, and i was completely dumbfounded by the results of the dyno last night! The engine tuner here is one of the most reputable ones around. he told me two of his other customers have had similar experiences.... one had a nisei piping kit and the other car had a custom piping kit.....
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
another friend uses the hks piping kit tuned by the same tuner, and no problems...
i'm wondering if anyone stateside has experienced this... for now the ARC pipe is sitting pretty in the trunk!
so on thursday (last night) i return to the tuner to find out that after ecutek i only got 300at the flywheel, and he said it should be the ic piping as he had seen this before.
anyways with the stock pipe back on the car feel really good and strong throughout!
i dont know if its just my car that is sensitive to ic pipes
i know it doesnt make any sense and i was in shock for the whole night yesterday! i had to demod to get power!!!!
ok, what happened was we tuned the car on monday, the sensor of the dyno was being replaced on wednesday so i would come in for a mivec touch up on wednesday to see the difference mivec tuning would play. On tuesday i did a drag with a mate of mine with similar mods except he had a high flow cat and no ecutek. I ran catless with ecutek. (both cars run arc piping btw) result was in first and second i would pull away but hardly anything in third. I also only felt low end improvements in the car and the high end didnt feel good.
Can you post both dyno sheets. Another thing i can think of(MR owners dont bash me) is with the ARC pipe was making just enought power to slip the clutch pack on the DCSST. But i doubt this very much. Or maybe some kind of half *** limp mode limiting your power one day and not the other.
There is no doubt Rhomel's a good tuner, just unfortunately not a very good problem solver. Paying customers want results when they pay for a tune, not a list of what MIGHT possibly have caused a problem during the tune. I've been down the road of interchanging my stock parts back, just so to test out if they were the cause of a malfunction and trust me, it's freaking tedious and time consuming. It's not funny too when at the end of the day, the problem still persists.
With regards to your problem, i highly doubt it to be the fault of the upper intercooler piping.
Having been down your exact road, i suggest you fix back your ARC upper intercooler piping and try out other reputable tuners. It's always good to have different perspectives to a singular problem. Andrew from BMS, Benny from Dynotechnica or simply GarageR would be a good start.
I think a boost leak would make sense; he shouldn't be LOSING (not loosing!) any power, especially not 40hp or whatever it was.
Have you figured it out yet? I remember seeing a thread not along ago where an MR was being dyno'd and the dyno rollers weren't rolling at the same speed and the ASC (?) stepped in and cut power. I'll see if I can find the thread I'm talking about maybe it could help you.
Got to be a boost leak. UICP gains about 10 whp; it doesn't lose 40. Something wasn't installed right. Maybe the couplers were loose, or maybe they were too tight and the hose was pinched, causing a "tent" to open and create the boost leak. Who knows...
