How Much Power Will The Stock 'X' Air Flow Sensor Handle b4 reaching max Voltage?
I'm finding this out right now. With the colder (read: more dense) air, I'm getting a CEL and limp mode whenever I stomp on the gas. It's just a matter of adjusting the air flow limit table.
Now, as far as absolute maximums...I'm not sure.
Depends if the housing is stock. Many of the intakes come with slightly larger MAF housings which scale the MAF and increase it's capacity. I'm sure if you do reach the limit, it is a imple matter of getting a larger housing and retuning.
Thanks for that bit about the 'air flow limit table', I will do some research on that.
I'm looking for a power limit b4 the AFS/Housing or intake has to be upgraded or tuned to read more air.
