Mivec advantage?
Old Jun 3, 2010 | 09:32 AM
  #136
Golden's Avatar
For the Evo X MIVEC, simply download an 08 GSR ROM. There are a handful posted around here. Gunzo maps come to mind.
Old Jun 3, 2010 | 10:27 AM
  #137
LaXGSR's Avatar
Gunzo maps have modified mivec, but for stock evo x mivec, there is a thread on the other forum called "Stock ROMs". Most versions of the USDM evo x rom are available there.
Old Jun 3, 2010 | 02:47 PM
  #138
Golden's Avatar
Doh! I have a copy of the Gunzo maps I refer to all the time for the 08 GSR maps. (not the data) So I wasn't even thinking.
Old Jul 10, 2012 | 01:50 PM
  #139
chetrickerman's Avatar
Veteran: Army
Originally Posted by tephra
ok so here is a question for you.
too much cam overlap means you will be over scavenging. IE you will be flushing good/fresh air + fuel down the drain... IE you will be throwing the baby out with the bath water.
So how do you detect this event? Can monitored AFR's help us?
ie If you tune for 11:1, then slowly add overlap (ie retard the exhaust) and you then see the mixture going suddenly lean does that mean you have too much overlap?
bump
I add a substantial amount of fuel to combat the leaning out, but how do I know if that air/fuel mixture is going right through the cylinder at low rpm due to the aggressive MIVEC?
moparfan
Mar 18, 2021 11:28 PM
razorlab
30
Jul 4, 2010 08:03 AM
kozmic27
Evo X Dyno Results
47
Jul 1, 2010 08:35 AM
Hiboost
Evo X Dyno Results
68
Nov 11, 2009 11:14 AM
PERRIN_JOHN
24
Apr 23, 2009 12:01 PM
