drop in intake ?
drop in intake ?
im looking to upgrade the intake on my 2008 mr and i just wanted to know which drop in intake would be best the k-n or hks and if theres any more or any different brands please note them to help me with my decision? and are there nice gains with the drop in intake?
heres the works drop in http://www.worksevo.com/store/produc...roducts_id=501
heres the test they did with hks and works https://www.evolutionm.net/forums/ev...-vs-works.html
Check this out, not a drop in filter but all you need is a filter and the MAS adapter...
https://www.evolutionm.net/forums/ev...t-results.html
My suggestion would be to go the tuning route before an intake no matter what tuning solution you go with. It's always good to have the tune or a plan for a tune under wraps before changing hardware.
Thanks,
Thanks,
Generally the biggest gains also come from a tune when dealing with a turbo vehicle. At the same time I can appreciate the expense involved in the tuning avenue for a first mod after buying a $40k vehicle.
I think we're kind of saying the same thing for the most part. Where my philosophy differs is in that I believe the tuning solution is the most important part of modifying a modern vehicle. Most modern ECUs, including the Evo X, require a programming change to properly deal with the modification(s). Without a programming change a modification may "work" depending on how far out of spec the parameters are pushed. There for my first step in modification will be to find the right tuning solution.
Generally the biggest gains also come from a tune when dealing with a turbo vehicle. At the same time I can appreciate the expense involved the tuning avenue for a first mod after buying a $40k vehicle.
but i thought you were saying to tune and add bolt ons later, so i was saying it'd be better if you tune with those hardware installed first to get the full potential of the new hardware as well.
Im with endgameXIII on this, I know the x has the safest factory tune on the face of the earth, but I would not want to put a 93 tune on the car, change intake, exhaust, etc and then have to pay for another tune (possibly dyno time) for those minor mods. It would be another thing if I was changing cams or trying to set boost at 28-30psi, I would definitely understand robb's theory with wanting that baseline before modding.
r0ck3r
53
Oct 25, 2006 06:56 PM
