ECUFlash 1.41 released
ECUFlash 1.41 released EVO X CAN Support
http://openecu.org/index.php?title=EcuFlash
2009-01-29: Version 1.41 released
* -- EcuFlash Related Changes --
* add support for EVO X CAN reflash
You will most likely need Microsoft Service Pack 3 if you don't already have it.
has any1 installed this version yet? I would like to see what the new .xmls look like (88590015/9base) w/ out having to un-install the current version... I can see they added support for the evo X, subys, and evo's 5/6 but has there been any worth while patches for the 7, 8, 9's? Im trying to see if its worth while to upgrade at this point... I have pretty much all of the newer patches that have came out prior to this version release.
mrfred: the .xml's that you provided a while back, (88590015/9base) is that the "new" entire .xml for this new version? Has there been anything added since you provided the .xml's? Im using the .xml's you provided! in 1.39.
Ok so w/ 1.41, you can use a 1.3 cable for 9's and under, just not the X's... or you can NOT use the 1.3 at all w/ 1.41?
TIA
TIA
