Thrust Bearing!!!
Thrust Bearing!!!
I finally found out what my problem is in my car!! its the thrust bearing!! now. what is the best advice for a thrust bearing thats been going out for a month now. the clicking noise when i push the clutch in only happens sometimes. please help!!! oh yeah. its a evo 9 mr. Thanks!!!
are you sure you mean thrust bearing
and not throwout bearing
throwout bearing could make a clicking sound or a squeeling sound
is the bearing you talking about in the engine or in the trans?
if you are in fact talking about a thrust bearing depending on how bad it was when pulled out i might install a new set of main bearings or pull the motor and send the crank out for inspection
if its the throwout bearing just put a new one in as long as the the old one didnt lock up and the pressure plate good
FS[MidWest]: OEM Thrust bearings - New
Piro Fyre
Aug 16, 2015 06:54 AM
Seancj
Jul 2, 2015 09:07 AM
quiquepr69
Jan 16, 2012 07:55 AM
