View Poll Results: Most important gauge besides boost:
Fuel Pressure
![](https://www.evolutionm.net/forums/images/polls/bar2-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar2.gif)
![](https://www.evolutionm.net/forums/images/polls/bar2-r.gif)
![](https://www.evolutionm.net/forums/clear.gif)
2.96%
Oil Pressure
![](https://www.evolutionm.net/forums/images/polls/bar3-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar3.gif)
![](https://www.evolutionm.net/forums/images/polls/bar3-r.gif)
14
10.37%
Oil Temperature
![](https://www.evolutionm.net/forums/images/polls/bar4-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar4.gif)
![](https://www.evolutionm.net/forums/images/polls/bar4-r.gif)
5.93%
EGT
![](https://www.evolutionm.net/forums/images/polls/bar5-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar5.gif)
![](https://www.evolutionm.net/forums/images/polls/bar5-r.gif)
4.44%
AFR
![](https://www.evolutionm.net/forums/images/polls/bar6-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar6.gif)
![](https://www.evolutionm.net/forums/images/polls/bar6-r.gif)
102
75.56%
Voltage
![](https://www.evolutionm.net/forums/images/polls/bar1-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar1.gif)
![](https://www.evolutionm.net/forums/images/polls/bar1-r.gif)
0.74%
Voters: 135. You may not vote on this poll
Most Important Gauges
I agree for tuning, but what about while driving? Safe tune, mildly modified, just daily to work, and some sporadic track time?
Maybe a better question is:
Say the tune has already been dialed in, and is daily-driver safe. What makes AFR important enough to be available at a glance, over the other options, in that situation?
Not contesting your knowledge, just trying to educate myself.![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
- vacuum line can pop off (or split) the FPR causing you to run WAY lean under boost
- Injectors can foul causing you to run lean in open loop and generally crappy elsewhere
- boost leaks will cause you to run rich under boost and lean off boost
just a few conditions a wideband will help you spot before they become a serious problem.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
I know this is late in the game, considering it's been a while since the last post on this thread, but what's the difference between an AFR gauge and a wideband AFR? I know the wideband is almost quadruple the price (not sure why).
idolized
40
Jun 4, 2012 01:47 AM
