P1241 Torque Limit Exceeded (COBB AP)
Once in a while I get this code, stating that I have exceeded the torque limit tables preset. I searched and looked for an answer on how to fix this issue. Currently running a COBB Stg.1 + SF Intake 93 Octane map.
Does anyone have a ideas how to adjust the map to set the torque limits higher in the COBB AP user menu's. I am not familiar with the COBB Race Software. I tune my other car using the Haltech Software, but the interfaces are a bit different.
So what I am basically asking if you adjust the torque tables will the code disappear as well. It throws it everyonce in a while, it just gets annoying on the highway.
I had this same issue but continually went into limp mode when I threw it. I would check for some boost leak with your hard pipe because the air flow sensor might be seeing a discrepancy in the readings. I am sorry, but I can't help you as far as the software/tuning is concerned.
I responded to your thread over on our forums. Check that your MAF sensor is clean and functioning properly. Also, when you say you are running the Stage 1 map, is that a stage 1 map for the SF intake or are you just running the stage 1 map for the stock intake, that could be part of the issue. Your post is a little unclear.
Travis
COBB Tuning
Travis
COBB Tuning
I generally would up parts of the table like 5 points and test that. If you obb the stg 2 to stg 1 table, you will see what valves they changed for which table. Then you can adjust accordingly. Also go do some WOT pulls (closed street/course of course) and datalog the loads, rpm, and throttle % among other things. Then you can see what load points you hit where.
I got P1241 a couple of times when I tried to accelerate hard out of a stop light with traction control on. But when I make sure the traction control is off, I don't have any problems. I'm not talking about the 2-step, just slipping the clutch at a redlight and pulling out hard...
http://www.***************/forums/sh...ad.php?t=17255
If you swap back to the stock BOV, then you will not have a problem.
The cause of your problem is the VTA BOV which you did not mention on here, but you mentioned over on the other forum.
Right now I am still testing the FORGE RS and I did not throw a code yet with the new setting I tried.
There is absolutely no Performance reason to put a VTA BOV on a stock turbo Evo X. NONE. I challlange you to find a single reason. It is pure RICE to put the POS BOV on an Evo.
