Torque limiter #1-#4 in ECUflash for EVO X MR
#31
I downloaded the GSR map that you posted and it has #4 airflow/torque changed. 1 through 3 are unchanged.
So what are you saying NOW? Are you saying that the changes in #4 in the GSR map mean nothing? Why did you change the numbers in #4 in the GSR map if they mean nothing?![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
The maps I provided will never trigger the CELs under normal conditions .. thats why the limiters are not touched ..
#33
I have seen EDM GSR, EDM RS, JDM RS, USDM GSR and some tuning ROMs - #4 Torque Limiter and #4 Airflow Check tables everywhere the same.
We adjust our cars approximately on 400 Hp and 480-500 Nm (intake, exhaust, 1.55 -> 1.45 bar boost). First time we have used JDM RS 1-3 Torque Limiter and AF Check tables and anytime we have had problems with P1241 code and limp mode.
Now we are using other tables from any tuning car. They are made approximately how has described Hiboost in the post #2, and don't have any problems. I can show these tables are not a secret, but this one from Rallyart ROM and I know rules where it is told "do not post..."I will make as you will tell...
doghead
Aug 29, 2010 06:06 PM
jpierson77
Jan 26, 2010 06:56 PM
LVSBB6
Mitsubishi TC-SST Discussion
Dec 8, 2009 11:49 AM
Fourdoor
31
Oct 31, 2008 07:05 PM
