Safe to drive untuned?
Everything else can be installed and would actually probably be fine as long as you're allowing the ecu to control the boost. If you're feeling parnoid, hook the wastegate actuator straight to the compressor outlet, bypassing the stock boost control system.
harrisonk531616
Oct 1, 2009 07:04 AM
denolloyd
76
Apr 10, 2007 02:35 PM
