MAF Scaling Table in grams/second
You can use the one xPRimNT posted and it will be 40-40-50, just be sure to use his evo10base lines too or else it'll be all screwed up
The number of elements is the number of items in a chart. SiC explained it very well. The tables tephra posted and the tables I posted have the same total elements (or items). The only difference is that in order to display them on the screen easier, the MAF Scaling table is split into three, and the location of the split is different. The ECU doesn't care where ECUFlash has the split, it just sees the final values.
40-40-50 in my case is the same 130 values as the 44-44-42 tephra has. I got mine from gunzo, so I don't claim to be an expert by any means, but either will work. If you just want the values to be different and still use tephra's addresses, I would imagine you could just compare the calculations and adjust the formulas.
Changing either one changes the other. That was the only way I could think to test it.
I was hoping that my addresses were wrong, because I thought that was the answer to a problem I had been having previously. However, they are changing the same values, so that theory was out.
U need to delete line level="1" from #2 and #3 tables in the evo10base xml
Friends, what do you think about my assumption that the correction factor of MAF scaling is constant and equal to the relation of the areas of section stock and a tuning intake in the maf-sensor place location.
I tried to put these files in my XML files but no new tables come up. I am trying to open my STOCK OEM 80020 file I downloaded from the ECU.
I put this file into my 52680020.xml
Add to 5268xxx.xml
<table name="MAF Scaling Part 1" address="5753a">
<table name="Volts" address="615ea"/>
</table>
<table name="MAF Scaling Part 2" address="57592">
<table name="Volts" address="61642"/>
</table>
<table name="MAF Scaling Part 3" address="575ea">
<table name="Volts" address="6169a"/>
</table>
and I put this file in my evo10base.xml
<scaling name="MAFVoltScaling" units="units" toexpr="x*5/1024" frexpr="x*1024/5" format="%.3f" min="0" max="5" inc="1" storagetype="uint16" endian="big"/>
<table name="MAF Compensation" category="Fuel" type="2D" scaling="AirFlow16">
<table name="X" type="X Axis" elements="40" scaling="MAFVoltScaling"/>
</table>
<table name="MAF Compensation #2" category="Fuel" type="2D" level="1" scaling="AirFlow16">
</table>
<table name="MAF Compensation #3" category="Fuel" type="2D" level="1" scaling="AirFlow16">
<table name="X" type="X Axis" elements="50" scaling="MAFVoltScaling"/>
</table>
But no go... am I doing something wrong... grrr
Add to 5268xxx.xml
</table>
</table>
</table>
</table>
</table>
</table>
i added the same patches to base and rom file and nothing changed in ecuflash.... is there a particular spot the patches need to be placed. i placed them at the end of the fuel contol lines...?
ok i have a comment/question. why do people change the MAF scaling? are you guys seeing abnormal LTFT or STFT and you want to fix them way? cuz i adjust my LTFT and STFT with my latency scaling and injector scaling when i put in my DW 1000cc's and they're fine.
my understanding of the MAF is that its just a sensor... so even by replacing the intake system you're still going to use the stock MAF housing on most intakes (to my knowledge) so by getting an intake system you're just creating a better flow of CFM, correct? but that same CFM is still going to go through the same MAF as before, granted better flowing but the difference should be minute shouldn't it? and it's a sensor that should self correct itself i thought. Maybe i'm wrong.
and how does getting a different intake affect timing? or does it not? cuz i don't see how it could.
Criptballer:
When you modify anything upstream or down stream from maf sensor it throws of maf reading. Air mass will now flow differently through maf sensor housing which will either favor more or less air flow, and in the case of the evo X..... most aftermarket intake systems i have seen actually have a whole new maf housing which is most likey larger which will read alot different than stock unit which is calibrated from factory to read with given diameter of housing. So larger housing would have a maf sensor capture less of whats actually going into engine, which would give you a leaner condition which the o2 sensor would pick up in closed loop and add fuel to compensate. make sense?
