EvoScan 2.6
Hi everyone,
Could you please tell me what i need to do for getting EvoScan program? I have paid the program via this link http://www.limitless.co.nz/# and from my account has been discarded 25$. I did it 4 days ago, but I didn't get any links for downloading. May be someone know how can I get the program an serial? Any help is needed.
Hi everyone,
I still can't get this damn LC-1 to start logging. I have the vista 64 drivers for the keyspan adapter installed. This was the first time I captured a log with V2.6 and afterwards the wideband calibration was lost. Not sure why this happened.
EDIT: The INT and EXH mivec are also still reading exactly alike. Does anyone have the right address and formula for the INT mivec?
When logging, often bluescreen showed
Hi,
EvoScan 2.6 often shows a blue screen to 2 or 3 times. The kind of errors is 'STOP ERROR' and the cause is indicated with usbser.sys. It's always the same cause. I began to use EvoScan from 2.5b19, and the same error had occurred to 2.5b19.
For information, my ECU ID is 52360018 modified for mode23. I use Windows XP SP3, tactrix OpenPort 2.0, LC-1 and an USB to serial cable. I'd thought USB cable connected to OpenPort may have problem and exchanged it, but the problem was'nt be fixed.
Logging just wideband O2 value by LC-1 & LogWorks3.1, no errors have occurred yet.
I reported this problem in ticket, but there are no answers for the moment.
Is there a person who has same experience? What can I do for the probrem?
